Milwaukee Fire?
sideshowjim
Northwestern Wisconsin
If nothing else, my view of a state wide 700mhz trunking system has spurred some of the forum members to comment.
I probably should have put my glasses on and slowed my hunt'n & peck'n down and typed 7/800... either way, I still believe there will be many counties holding off with logging on to a new 7/800 WISCOM system, unless there is large grant monies available to offset the enormous costs, and not to just the law enforcement agencies, but for the many rural fire departments, EMS and first responders....
Yes, I fully understand some counties here in the northwest have migrated to the WISCOM, Dunn CO is one of the systems I monitor. I have heard some counties like Rusk using RCALL61 and others using RCALL51 as well as a few other WISCOM talk groups, that said many of the counties around here still use "Point to Point" too.
A 7/800 trunking system only makes sense, especially for the WI counties bordering with MN like St Croix County, for the interoperability with law enforcement in both states, and few of the bordering fire departments have mutual aid agreements with each other on both sides of the St Croix river...
I attached a simple graphic of the many county systems I monitor either from my home or while on the road... not included is the Minnesota ARMER system I also monitor while on the road. I do occasionally get down the southeastern portion of the state, and have "dialed in" to a 700mhz system in Milwaukee (just say'n)
I look forward to the wealth of knowledge y'all are sharing!
  • County-WISCOM.pdf
firebell9137
I’m confused. When MFD switched to closed sky, they got a boatload of talkgroups. They seemed to have carried that over to their new P25 system with 143 talkgroups plus their conventional fireground channels (15.)
Why on earth do they need so many talkgroups? They can I’m not saying they can’t but in comparison, Detroit has 19 talkgroups and about 10 fireground channels.
MFD’s minimum staffing is 213 Firefighters/Officers/Batt Chiefs and Medics. If you remove the Med units that are on a different system, pretty much every firefighter gets a talkgroup.
If anyone has the reasoning behind this I’d be curious to know why.
The Milwaukee Fire Department uses dedicated radio talkgroups and profiles for medical (EMS) calls to separate heavy patient-care traffic from general fire dispatch and administrative operations.High Call Volume: Over 80% of the responses handled by MFD crews are medical emergencies. Keeping EMS on dedicated talkgroups prevents routine or continuous medical coordination from clogging the primary fire dispatch channels.Hospital Communications: Paramedics and Mobile Emergency Department (MED) units need distinct tactical channels or profiles to relay patient vitals and status updates directly to receiving hospitals or medical control.County-Wide Interoperability: Because MFD operates on shared regional infrastructure (like the Milwaukee County trunked system), specialized talkgroups allow seamless coordination between city engines, specialized paramedic units, and suburban mutual-aid or backup EMS providers.
