Mini USB Cable
Ishmole
Walden, NY
So far I have had two USB cables that have stopped connecting to the scanner when attached to the computer. The cables connected fine for programming for a while, then quit working. When I use a new cable, it works for a while, then also stops connecting.
Has anyone else experienced this?
dave3825
Suffolk County NY
I use @ProScan for programming my 200 so my original cable does not get much use. Are you using the front port with the cable?
Ishmole
Walden, NY
Yes. The front lower right mini port. I am using ARC 536 Pro software.
fxdscon
¯\_(ツ)_/¯
Your thread title says "MINI" USB cable.....
You are using a "MICRO" USB cable in the front port?
iMONITOR
Silent Key
S.E. Michigan
Maybe some dirt got into the socket? Maybe give it a little squirt of "plastic safe" electrical contact cleaner. Make sure it's not bent or damaged in any way.
Ishmole
Walden, NY
My error, sorry! It is a MICRO usb port and a MICRO cable.
N1NCZ
Conway, SC
Also leave mine plugged in all the time - use a switched usb port to the computer
n1chu
Farmington, Connecticut
I also leave my programming cables plugged in and use the Butel ARC software. No problems have arisen with either the OEM or the 90 degree angled replacement cables I use. Could you be having a problem with your computers Com ports being lost on occasion?
