Tytera TH-9800 plus programming software communication timeout
itsnamda
Hey all so I just picked up a TYT TH-9800 plus radio and I tried doing some programming with the software that was available for download from the Radioddity website under TH-9800 but when I try to read or write from the radio it just gives me a "communications timeout" error. I've been successful programming it from Chirp so I know the radio and cable are fine and it's just a software issue, but I want to use the TYT programming software since you can modify the transmit and receive ranges of the radio. I've been told that there is a specific software for the "plus" model which is not the one available for download from Radioddity and that may be why this isn't working. Does anyone have any insight into this? Haven't been successful finding anything.
itsnamda
Following up on my original post here to close the loop for anyone looking for an answer.
The software provided on Radioddity's website which is labeled for TH-9800 plus and dated most recently for November 2025 simply doesn't work. I talked to someone at Radioddity and they were able to provide me with the original TH-9800 programming software dated 2022 and that worked perfectly fine.
This is the direct download link they sent me: https://radioddity.s3.amazonaws.com/TYT_TH-9800_Software_20220829.zip
VK5OM
This is very annoying. It appears my radio is shot. (replaced once) Two computers, a myriad of drivers, will not communicate with TH-9800 Plus BUT will communicatte with TH9800. Using the TYT cable
diverdowndh
this vers does work, but does not give you the needed options for DCS TX and RX like the Newer vers does.
nanook001
Lafayette, IN
I too am having issues with the 9800 plus radio program that I downloaded from TYT TH website. First, I tried using the disc that came with the radio only to find it contained a group of files and no direction for which to use for programming. I gave up with that.
The 9800-web program has spots to install rec freq's and xmit freq's but no repeater + or - shift. I added the freq's shifts manually to the program and uploaded to the radio. Then operating the radio each channel indicates a +- that indicated it's a split shift. Any thoughts?
Lwolf1313
El Mirage, AZ . USA
I have the TH-9800 plus and the software version to use is 2.08. I tried using that newer software as on the Radioddity's site and it does not work. That software may be for the TYT TH-9800D Plus
Lwolf1313
El Mirage, AZ . USA
I have the 9800 plus purchases before 2025 and RT SYSTEMS has two choices to download, pre 2025 and the 2025 or newer version.
