Minitor 7 Software
AFD103
Has anybody else had the pleasure of using this steaming pile of hot garbage yet?
The first thing that hit me are the numerous spelling and grammar errors. I can forgive one or two. I gave up counting after a dozen.
I suppose it was to much to ask to be able to either open or import a Minitor 6 file. Since it hasn't been a thing in previous software, I didn't really have the expectation that it would be a thing here.
But since it's not a thing in Minitor 7 software, how about Copy and Paste actually working? I can open Minitor 6 and Minitor 7 side by side. I can copy and paste the receive frequency data. But when I try to copy and paste tone data, Control-V doesn't work at all. You can right-click and paste. The data gets pasted into the field. But when you save or program, it doesn't actually stick. It sucks when you have a five-channel pager with anywhere between three and 10 tone sets per channel.
If you can stick with the Minitor 6 for a while, do it. They are significantly smaller than the Minitor 7, functionally identical, and the software isn't nearly as buggy.
NCFire11
I was wondering what the difference was. I saw the 7 was larger but did not seem to have many more features.
northstarfire0693
North Carolina
Why does M keep changing pagers? The II was the best out there, but I can understand why they moved to the III due to being able to program via software. The III and IV were crap. V was decent. I don't have any experience with the VI or 7, so I cant say anything about them.
AFD103
Based upon everything I've seen so far, the feature set is fundamentally the same. There's an 'emergency alarm' feature in the 7 that basically makes it shriek. Basically like a manual PASS alarm activation. Otherwise, I could find no significantly different features.
They are finally getting away from charging the pager from the accessory connector on the bottom and have put charging contacts on the sides. The pager has been made taller to accommodate those charging contacts.
Rudy3145
New York
Just like the Iphone - they keep changing for $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
MendoRadio
Shingletown, CA
Anyone have the issue that it just won't take what you give it? Wrote a whole F'ing file for it and did the "writeing" and it acted like it programmed successfully but literally took NOTHING. Also saved the file... it ate that too... da hell man?!
Rudy3145
New York
Why is it larger than the 6? Its the size of the original Minitor! LOL
AFD103
Yep. Several times.
It's virtually the same profile as the 6, but a half-inch taller. They made it taller so they could add the side charging contacts, rectifying a long-standing problem with bottom-mounted charging contacts that got dirty and corroded.
brooksde
Patchogue, NY
I've been selling alot of Minitor 7's and you are correct about everything. I have to read/write several times and use the Clear Tones to hopefully get tones deleted since it won't delete any other way.
wa8pyr
Lead Database Admin
Ohio
Is Unication still making Motorola's conventional pagers? If so there's your answer.... crappy translation. Nothing new with Chinese software, although I'd have thought Motherola would have been a bit more attentive to stuff like that.
GTR8000
NY/NJ Database Guy
BEE00
Unication manufactured the Minitor III/IV/V for MSI, not the VI or 7.
I had a problem with data not sticking in the "User Data" window, and I noticed I didn't see any "save" or "ok" button. I am a Professional dealer for Moto and opened a ticket. Their answer was that I simply missed/didn't notice the "Ok" button at the button. I went back and still didn't see it, but I was using a 10" Panasonic FZ-G1 tablet, so I connected an external monitor (As "extended", not "duplicate") and discovered the buttons at the bottom. Program window formatting isn't universal and seems to be a common problem. I was able to get data saved every time with hitting the "Ok" button. Thanks Moto...
13SQF2
Porterville, CA
Any luck with opening a ticket. I click the OK button at the bottom and still cannot get it to save any of the two tones I put in. I can save frequencies but not two tones. Frustrating! I would love to use my new Mintor 7 as a pager but can only use it as a scanner until they fix the programming software issues.
Well that's extremely frustrating, and now I need to go back and make sure it's actually taking the data! I always verify but this makes me want to double check...The ticket I opened didn't even get to a Q&A phase with support, it was simply "You didn't see the 'ok' button, ticket closed", but if I continue having issues, I will absolutely re-open it.
13SQF2
Porterville, CA
I have tried the software on 2 different computers with different operating systems and cannot get the two tone data to write to the pager, can't save the two tone data, all I can get to write is the frequency. Definitely a Motorola software issue. They supposedly released a version 1.2 according to the release notes but when you download the software it it still the 1.1 version. This is garbage. I have had no problems with Unification. If you are programming two tones I would test them before you ship them to customers.
trp2525
...They supposedly released a version 1.2 according to the release notes but when you download the software it it still the 1.1 version...
You can download the Minitor 7 CPS R0102 from the UCC Wireless website. It is definitely version R01.02 as I downloaded and installed it on my computer and the "Help" "About CPS" in the program confirms version R01.02.
I have also attached the release notes for version R01.02 in case anyone is interested in what has been changed/updated. Per the release notes: "Please uninstall the previous version of MINITOR 7 CPS before installing the new one."
  • minitor-7-cps-release-notes-r02.pdf
