Minitor IV HELP
nick223
Ottawa Illinois
I have a Minitor iv that wont decode the tones to drop the page Any one have any ideas whats wrong and the fix? The speaker works because when its on open scan you hear the traffic. all the numbers and freqs are right.
NCFire11
Decoder board is probably fried.
As long as the tones are entered correctly I dont know what else it could be.
jmfirefighter
Raymond, NH
I agree. As long as the tone values are correct, the pager should be alerting. They are a pretty simple electronic device........
If you can, read the codeplug from the pager to ensure it's all correct and then rewrite the pager. I had a IV that would "loose programming" every now and then, and this usually worked well.
Minitor I, II, III, and IV WILL all work with narrowband. The only difference is that you may have lower audio volume, and you may have a smaller range away from the transmitter depending on your terrain and the height of the transmitter.
NCFire11
Yep, Mother /\/\ wants everyone to believe that they wont, but they will. We are keeping all of our III/IV's for backup pagers if something happens to our Vs.
ffexpCP
wizard of odd
Michigan
Minitor 3/4 circuit boards are very thin and flimsy. Over time, use of the belt clip pushes on the board and IC and eventually breaks solder joints on the tone decoding chip. Great design, huh?
ffexpCP
wizard of odd
Michigan
Sometimes. It can be a challenge. You need to be REALLY good at soldering, have a very small tip, and a steady hand. I've fixed a dozen or so, and only destroyed one. And you run the risk of destroying the case opening it up too.
mojo3120
The IV's are pretty easy to open, the III's on the other hand are damn near impossible. Brute force is about the only way I can ever get them open. Anyone know of a method to open a III without breaking the clips/tabs?
mojo3120
oh but have you seen the fix? Now that's some engineering :)
ffexpCP
wizard of odd
Michigan
The piece of foam? That still doesn't help? and leaves adhesive behind so solder won't stick when you try to fix the broken joint?
