Minitor vi issue?
sfd119
So I programmed my VI and set the tones and all the settings I want but am I missing something, When the tones are alerted, it sounds with no problem, but I get squelch until the broadcast starts. Is there something I'm missing? I'm new to the voice record minitor.
I have the reset on revert N...is this right> Shouldn't it alert without the squelch for 7.5 seconds.
This is normal operation. It's caused by your Dispatch Center not leaving the carrier open between the page(s) and voice portion. The minitor thinks its done receiving a signal.
silencedsoul
Lewistown, PA
Thanks,
It's works fine, but the only thing is the squelch between the alert and voice dispatch. After the dispatch, I still have to reset it because of the squelch.
sfd119
Thanks,
Yes, again, normal operation with Stored Voice configuration.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Thanks,
Does the radio mute properly when the voice message is completed? If so, then the open squelch between the tones and the voice message is normal behavior. Annoying, but normal.
If you'll search minitor revert n here in the Motorola sub-forum, you will find a good number of discussions about this same behavior on the Minitor V. It all applies to the VI as well.
