On P25 trunked systems (especially multi-site), the scanner sometimes appears to be "holding" on the active talkgroup but still misses the reply transmission after a dispatch. This is a common complaint.
Key Settings Explanation
- Talkgroup Delay (set to 2 seconds): This is the "hang time" the scanner stays on the talkgroup after a transmission ends, waiting for a reply.
- System Hold Time (set to 1 second): This controls how long the scanner stays on the entire system (checking sites/control channels) before moving to the next Favorites List or system.
The mismatch (2s delay vs 1s hold) often causes the scanner to resume scanning the next system/site too quickly, missing short replies on trunked P25 systems (which have very little built-in hang time on the voice channel).Recommended Fixes (Try in This Order)
- Match or Increase Hold Time
Set System Hold Time to 2–4 seconds (at least match or slightly exceed your talkgroup delay).
Many users find 2–3 seconds works best for P25 trunked systems. A hold time of 0 uses the scanner’s minimum (~1–1.5s per site), which is often too aggressive when monitoring multiple sites.
- Adjust Talkgroup Delay
Try lowering talkgroup delay to 1–1.5 seconds (or even 0–900 ms on some tests) if replies are very quick. Higher delay helps with casual listening but can make the scanner "stick" and miss activity elsewhere.
- Other Important Tweaks for SDS100
- Reduce the number of active sites/Favorites Lists if possible — scanning two sites + DMR conventional slows resume time.
- Ensure P25 Wait Time (under conventional/digital settings) is low (0–400 ms) to avoid clipping the start of transmissions, though this is more for conventional mixed-mode.
- Advanced/Last Resort
- Create a dedicated Favorites List with only the critical P25 systems (one max) and scan it separately or prioritized.
- Compare exact audio start times side-by-side with the Whistler/TRX-1 to isolate if it's decode latency vs scanning resume.
Quick TestSet one critical P25 system to:
- System Hold Time: 3 seconds
- Talkgroup Delay: 2 seconds
- Scan only that list + minimal others
I'm fairly close to BG and frequent North Baltimore area, PM me with your contact information as I'm very familiar with the systems in that area and can share some programming with you.
