SDRTrunk Missing calls - Site Review
PtBreak
OCMD
I've searched on the forums to find a solution to two issues I've been having with a site I added.
First issue was missing calls when they key up back to back so I added an additional dongle to hopefully fix that issue.
The second issue was the calls would sometimes sound garbled and like it was a robot that was corrupted.
I manually adjusted the gain and the PPM which I read could of been an issue and since then they have been cleaner and sounded better.
However I'm still missing calls with 3 RTL-SDR4 dongles running on a Pi4B with the RR Pi Image and SDRTruck.
Can someone take a look at my set up to see if I'm missing something?
I have all other channels I don't want to hear muted and off.
I've attached a couple screenshots.
Site Background:
3 RTL-SDRV4 Dongles
Ras Pi4B
Ocean City, MD P25 System on the Ocean City Simulcast Site Ocean City Site: Simulcast
769.26875c770.05625c770.85625c772.10625c772.43125c772.70625c
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
First off, running the waterfall for any length of time on a PI is a nono. It's eats up CPU like no other, and the PI has nothing to spare.
Secondly, maybe the PI + SDRTrunk and 3 RTLs is just too much for the PI.
I understand wanting ot see the waterfall, but don't evaluate any sort of performance (clear / garbled audio, etc) with the waterfall on. Turn it off before doing that. I don't care what anyone says -- a PI running SDRTRunk with the waterfall on is a CPU killer.
PtBreak
OCMD
I keep it off, I only turned it on for a screenshot and when I was adjusting the gains.
It def slows everything down so I never have it on unless I’m messing with a setting then it’s off and I also reboot the pi just to make sure every thing is fresh.
mtindor
FMP24 PRO USER
If that is the only system you are going to monitor, you should just need/use two dongles. If you are running the latest 0.6.1 Final version, under each tuner you can set a minimum and maximum freq.
I would set something like:
dongle 1
min: 769.25625
vfo center: 770.0625
max: 770.86875
dongle 2
min: 772.09375
vfo center: 772.40625
max: 772.71875
That way each dongle is only responsible for a certain block of frequencies, and the dongle won't have to retune to keep a hold of the control channel.
Might be overkill, but that is what I would do.. I see absolutely no reason for three dongles.
MIke
PtBreak
OCMD
dongle 1
min: 769.25625
max: 770.86875
dongle 2
min: 772.09375
max: 772.71875
MIke
I figured 3 might be overkill however I couldn't figure out why I still wasn't working.
Where do I find the setting for this? Thanks!
Edit: Think I found it I've attached screens for confirmation.
PtBreak
OCMD
dongle 1
min: 769.25625
max: 770.86875
dongle 2
min: 772.09375
max: 772.71875
MIke
It keeps changing the freq's you recommended I put in for each dongle, not sure if I'm missing or doing something wrong. It also sounds like I'm missing calls as well, any help is appreciated thanks!
mtindor
FMP24 PRO USER
CLick "reset" on both and forgot about it for now. Not sure why it doesn't honor min/max. I have those issues as well.
I guess you'll need enough dongles added to stop missing calls. You only should need two, but if it keeps barking with two then go with three.
You also should consider posting on the actual SDRTRunk Google Group or in their discord. But it should be able to be resolved here. I just don't have the answer.
PtBreak
OCMD
I’ll reach out on there thanks for trying to help, pretty frustrating maybe it’s a bug or something was hoping I was doing something wrong.
