repairman222
Believe it or not I live next to a county that still uses point to point, 155.370 mhz. There county is not with MOSWIN system. would anyone know the audio option, CTCSS? Thank you group members..
Most of the St Louis region still uses the old analog point to point channels. The same applies to the old Sheriff's net channel as well.Believe it or not I live next to a county that still uses point to point, 155.370 mhz. There county is not with MOSWIN system. would anyone know the audio option, CTCSS? Thank you group members..
Yes, I forgot to state the same for the St Louis area that no tones are used.In Tennessee 155.370 is open squelch no tones.
Mutual Aid and Sheriffs Net Has 156.7 listed I thought Mutual Aid might be the same 156.7?Most of the St Louis region still uses the old analog point to point channels. The same applies to the old Sheriff's net channel as well.
A far as the PL tones used, if your scanner can use tone squelch then it will usually also have a way to search for the tones being used when it stops on an active channel.
Should I leave it on Search or CTCSS SEARCH?Yes, I forgot to state the same for the St Louis area that no tones are used.
However, I think St Louis County does send a PL tone when they send the CW callsign for their license.
I always assumed they have their radios setup in reverse and mute the audio when the tone is heard.
Yes, leave search enabled. Some agencies use a search tone, but some others don't. Receiving stations obviously are in a no tone mode because 1 toned agency ca. Talk to the non toned.Should I leave it on Search or CTCSS SEARCH?
Its not tones, its the CTCSS NUMBERS.Yes, leave search enabled. Some agencies use a search tone, but some others don't. Receiving stations obviously are in a no tone mode because 1 toned agency ca. Talk to the non toned.
However if you happen to like a particular agency and they use a tone and you don't want to hear those who don't, you can then use the squelch tone.
Use Search so it will find both CTCSS type tones as well as DCS tones if any are being used.I monitored 155.370 all day today and not one station was using a squelch tone any longer. The county also appears to have stopped sending a PL tone when they broadcast the CW ID like they used to.Should I leave it on Search or CTCSS SEARCH?
Thanks for the info..Use Search so it will find both CTCSS type tones as well as DCS tones if any are being used.I monitored 155.370 all day today and not one station was using a squelch tone any longer. The county also appears to have stopped sending a PL tone when they broadcast the CW ID like they used to.
I didn't check 155.730. And 155.475 is used around this area heavily by Illinois as the channel they call ISPERN so I don't monitor it either. Most of the ISPERN traffic is DWI bolo's that are rather boring.
For regular point to point on 155.370, you probably won't find any tones in use these days. That's what I found today after several hundred calls logged but no tones logged at all.
Ctcss are analog tones and DCS are digital tones. These tones are squelch tones, not actual tone out tones.Its not tones, its the CTCSS NUMBERS.
So leave it on Search or CTCSS Search? Also what is NAC tones? Thank you...
DCS is for digital.repairman222, why leave it on search ?
you radio might get it wrong as i have heard about a digital tone being decoded as an analog one.
also CTCSS and DCS are for analog systems.
one is a steady actual tone in hertz and the digital one is just a digital signal on the analog signal.
both should not be heard out of you speaker
and the NAC thing is on a digital system and is also a digital thing as computer "talk" in ones and zeros.
If it left on search my radio will display the ctcss and i can store it to my unit.repairman222, why leave it on search ?
