Hotsauce142
- Joined
- Nov 29, 2023
- Messages
- 4
Hello,
New to the hobby and trying to learn as much as I can here.
I currently have a Yaseu FT-60 W/ Diamond MR77SMA used as a mobile rig.
I know this isn't ideal, but looking for insight on what can improve this setup now and for the future.
I made my own mount for the MR77SMA (See Below) that currently bolts to the fender/hood latch and has bare metal contact on both sides.
Also, a link is listed as to the issue I'm having while using this setup. I cant really make out more than a half of sentence more often than not.
Local repeaters are approx. 20-40 miles out. The one in the video is a little farther, and was the only one with traffic at that time for the video.
Identical situations will also happen on a more local level.
I understand there are NMO Antennas/Mounts that could offer a better solution to the Antenna I'm using now.
As well as NGP antennas given the small surface area.
I've looked at Larson and Laird antennas, but there's so many to choose from. I'm hoping someone with a similar experience or knowledge on the subject could point me in the right direction.
Here's my current requirements:
I'm not looking to drill/mount anything on the roof. My truck is lifted and clearance is already an issue.
Current antenna is 20". It looks like I could go up to as high as 38" without being too excessive. If there's shorter options that is preferred.
I would like to have dual band 2m/70cm as id like to monitor both.
I did find a Diamond NR770HNMO antenna that looks like it's compatible with a new mount.
However, some say there are better brands out there and I'm looking for a reliable solution.
I'm decent at metal fab. So, if someone has made something that works for their rig, feel free to provide insight.
I appreciate the help and thanks in advance for the feedback.
