The amplified charger works fine using a vehicle's 12vdc power. You can connect an external mobile antenna to the BNC connector on the amplified charger. With the 700/800 MHz antenna removed, my pager shows out of range on my local 800 MHz system. When I drop the pager into my amplified charger, I get full signal bars using the VHF 1/4 wave antenna on the back of the amplified charger. The amplified charger will fit in the center console in a lot of vehicles.Is anyone running any cool setups with their unication devices? I was thinking of possibly setting up the amplified charger to get that robust audio in the truck.
Did you remove the antenna from the pager? It is possible that the signals from the pager antenna and amplified charger antenna are out of phase and cancelling out each other or the 2 antennas cause directional reception. I would also try cleaning the contacts on both the pager and amplified charger.I initially tried the amplified charger route in a vehicle - ended up removing it in the end. I was having issues with going out of range, and when I pulled it out of the charger, i would go back into range.
I use my G5 sitting in a cupholder in the center console. There are no out-of-range problems using only the attached antenna. The audio is set to 60 which is plenty loud for me.Though frankly the pager works incredibly well just clipped to the visor - great range, reception, sound is loud even with some music on.
Which Bulletpoint clamp did you find holds the G5? I just installed the kit in my truck but the phone clamp it came with doesn't really hold onto the G5 very well. Love their design - thanks for sharing your setup.View attachment 167970View attachment 167969
Top is in my office Bottom is in my truck Both are Bulletpoint Mounts
Radio Holders
Securely mount your handheld radio, CB radio. hand mic or Magnetic Mic™.www.bulletpointmountingsolutions.com
Does the clip fit into the radio mount? Possible to get a pic? Thank you.Handheld Radio Holder with 20mm Ball
You bend it out ever so slightly and the groves on the pager fit into the tabs on the end of the mount
No you have to remove the belt clipDoes the clip fit into the radio mount? Possible to get a pic? Thank you.
I just got this one you suggested in the mail, seems to work great. I also bought a RAM small claw and clamped it to my grab handle, it is perfect.I have an alternate solution that I've been using. It is not as elegant the Handheld radio holder, but it works. I use the RAM® Finger-Grip™ Universal GPS and Radio Holder. The mount is set up to accept a 20MM ball mount that is bolted on the back. Holds a G1, G4/5 with no problems.
Here is the link to the mount on the Ram Mount site:
The RAM® Finger-Grip™ is a universal holder that can accommodate a wide range of devices including GPS, handheld radios, phones, bluetooth speakers, and much more. Included with the holder are three sets of four flexible rubber-coated fingers to grip your device. The main backing plate consists...rammount.com
If you need any further info, please PM me.
MC
