Mobile: Power lead T-Connector removal?
RandomGuy1
First mobile install (of several). I have radios from Kenwood and Yaesu that I plan to install in vehicles. Each on has a T-connector on the power leads at the end that plugs into the rig. Is there a way to remove those connectors for a smaller hole in the firewall, or is common practice just to snip them off and re-splice them onto the leads after they are passed through the firewall? Thanks!
dkcorlfla
Orlando
I think if you take a close look at the pins inside the connector you will find barbs on the side of the pin. In the past I have been able to depress the barb using a small hard wire and then pull the pins out of the plastic T. After you get the pins out you should be able to bend the barb back in the correct position using a knife or razor.
dkcorlfla
Orlando
Why can’t you run the wires from the inside out?
Good idea, should be faster and easier then removing the pins. If the power lead uses an inline glass fuse it should be possible to remove the fuse and wire connectors from the plastic case making the size of the needed hole smaller.
AK9R
Central Indiana
A set of picks may be helpful.
slowmover
Fort Worth
Welcome to Radio-R!
It’s easy on occasion to miss the picture needed.
In a vehicle with several devices needing 12VDC there are distribution blocks of various types to make all this easier. (BLUESEA).
I’ve a veteran WEST MOUNTAIN RADIO RigRunner 4005 which has gone into quite a few company vehicles over the years.
— Most single installs won’t benefit by acquisition of tools & supply for ANDERSON PowerPoles as needed for that device, but it was ideal for my situation.
Don’t be in a hurry re planning. Executing a good plan takes no time by comparison.
The bible of mobile installation will take you through quite a few topic headings worth your while. Search opinions of those topics as well.
Best install is demarcation between men & boys.
RandomGuy1
Thanks. I'll take a look.
Too obvious. I need a more complex solution. :) That's a great thought. There are fuses on the 'other' end of the leads, but they're less bulky than the T-connectors. I'll check and see if this is workable.
Now we're talking! An excuse to buy something! Good point.
I did mobile installs for many, many, many years and I don’t recall ever removing the power plug to fish wires through the firewall. Maybe I did it wrong all those years?
:) I think not. I'm trying to use a small hole in the firewall. If I go with a larger opening it might simplify things and render motion moot.
That part. Three decades of working in LMR and never saw the need to barbarize a radio power cable during installs or removals.
Leave it to a new guy (me) to complicate a simple task.
Welcome to Radio-R!
I thought about a fuse block but as you mentioned I don't know that it would benefit my install. Thanks for the mobile installation link. (y)
Thank you all for your responses. I will probably apply several suggestions as I work through these projects. I appreciate the thoughtful input.
KevinC
The big K
I'm everywhere Focker!
Chances are the wires won't be the exact length you need, so just cut about 6" from the fuse holder, use what you need and crimp back at the fuse holder.
Run one wire of larger gauge from a fuse at the battery to a fused distribution block at the radios. Less labor, less voltage drop, easier to change/add things down the road. Pull your ground off the body closer to the radios.
Those wiring harnesses that come with the amateur radios are usually kind of junky anyway.
slowmover
Fort Worth
This plan works, OP.
I plan for max draw of 30A and generally don’t get much above 20A. As a result I’ve used 6-AWG for years as those installs were 20-25’ total circuit length. I use it for shorter runs.
Otherwise, I stay with 10-AWG and splice it close to device being powered. These two wire sizes do the job for me.
No more than 1/2V drop DC at mic key-up. Assume device fuse rating is standard amp draw to determine wire gauge minimum.
Distribution Block makes it easy now or in the future.
ANCOR heat-shrink adhesive connectors, not just tinned, multi-strand ANCOR marine-grade wire. Plus split loom cover.
Build harness similar to OEM which can be removed as group.
Power is A System.
Mine begins at BATT with this fuse type
When the radio rig always gets high octane fuel it’ll always have killer throttle response.
— This may seem like “much”, but it’s nowhere near what you’ll see in research where @mmckenna has detailed some of his professional dotGOV installs.
— It’s nowhere near what my son is underway with installing an FT-891 & Little Tarheel for his pickup.
The plan is everything.
This is the typical Amateur 12VDC power system:
RandomGuy1
Thank you. Good info. I hadn't thought about putting the fuse block at the radio. That'll help if I decide to add a GMRS radio, too.
Power is A System.
Thank you for putting the effort into your detailed post. I got the temporary installation done and it's working fine, but I like this set up better.
In the long run, it saves you labor, and even if it's your own labor, that's expensive.
It looks better, you only have to dress in one wire. No wads of fuse holders at the battery, either.
Makes adding more equipment easier.
Gets rid of the awful power cables that most ham/consumer radios come with.
Makes troubleshooting a lot easier, but if done right, you shouldn't ever need to troubleshoot it.
Lots of clean power makes your radios happy.
I've got to do a new truck this week. 2 radios. It'll get the same setup.
VK6NCB
this is exactly how I would do it
rf_patriot200
Freeport, Illinois
Welcome to Radio-R!
I use the 4008H
Hard to get a good crimp on 14/2 romex
I was looking at a new Dodge 3500 the other day that someone had installed a large amber light bar on top of. A lot of 14ga stranded THHN run through the engine compartment, near the turbo down pipe, under the truck to the bed. In the bed there was a 8x8 PVC box where it spliced on to the cable from the light bar. Adhesive ty-wrap mounts up the back of the cab and across the roof. The amount of work put into doing it wrong was really impressive, in a nauseating sort of way.
I'm 99% numb to this stuff after so many years. I've learned not to comment, just blink slowly, grit my teeth, and walk away. Don't touch it, or you suddenly own it for eternity.
Glad it wasn't one of our trucks...
