Monitor Each P25 Frequency Manually
Bert_holbert
RICHMOND, INDIANA
I am having a hard time staying locked on to the control channel. But i have no issues listening to calls when i am locked on. i have 5 RTL-SDR dongles and my area only has 3 talk frequencies not including 2 control frequencies. my question is how do i setup SDRTRUNK to monitor these frequencies. when i use NBFM i get nothing but when i use p25p1 i get nothing. any ideas?
west-pac
There is likely a better forum for this question. You need help setting up your SDR, but not anything specifically related to Indiana.
Enforcer52
Voice Of The Piney Woods
Lake Livingston, TX
From looking at Wayne County, you shouldn't need more that 2 sdr's to monitor the traffic there as all the frequencies are within the 2.4mhz range of the sdr's. I suggest you watch the video below, even though it demonstrates setting up a system in Texas, it works for any location. After watching it, then replay it and follow the instructions precisely, stopping and starting the video as needed. Each sdr having a separate serial number is vital for it to work.
Feel free to send me a PM if you need help.
Bert_holbert
RICHMOND, INDIANA
i guess i didn't mention that i also am monitoring 5 analog EMS frequencies as well. so thats why i have so many SDR's. i have been streaming this SAFE-T system for several years now. ive just been thinking that if i monitor each frequency manually it would be better then using the control. i have no issues getting more dongles.
Enforcer52
Lake Livingston, TX
OK I see what you are trying to do, so I tried it on my system. SDRTrunk does not decode a channel if not directed there by a Control Channel. So what you are wanting to do is not possible from what I can see.
How far are you from the closest tower, and what kind of antenna are you using?
Bert_holbert
RICHMOND, INDIANA
i was getting frustrated by my low signal strength so in the last hour i was looking over my connectors and i found that the LMR400 line from the antenna was putting some strain on the pl-259 to type F adapter that goes to the signal spliter. It was pulled apart and the two center contacts were not making any contact. after some fiddling i was able to get it back together and now im at -10db. i was previously at -60db.
i am less then 2 miles from the main tower.
LJF
Island Park RI
I am in RI which has a 4 zone simulcast system.
Go into playlist editor select RR tab system view. the 4 zones are listed, highlight your choice and a list of freqs (LCN) will display in my case 9 including CC. use the create channel config to the right for each channel. I added each Ch separately save after each entry. click PLAY to activate each freq and you should be good to go.
