Monitoring a Motorola Capacity Plus Single Site system question
kickflip
Hi, I'm relatively new to cap+ systems and monitoring them. I was gifted a Motorola xpr3500e with no programming on it but it does include the cap+ single and multi site capability. I was wondering if I could monitor a single site system on it, and if there is a chance that my radio could get blocked from monitoring it. Thanks for any help or clarification.
CanesFan95
Analog already is interoperable.
FL
Yes. If the Cap+ system uses Restricted Access to System (RAS) and you don't know the RAS key, the radio will not unmute. There's also a very slim possibility that a system owner/administrator can send a kill command to inhibit your radio if they know your radio ID.
kickflip
Do all mototrbo systems have RAS keys or is there a chance what I want to monitor doesn’t have one?
CanesFan95
FL
You can use DSD+ software to tell if a CAP+ system is using RAS, but it's hard to set up and I'm not sure if that feature might require the paid version. The paid version is also invaluable for figuring out the LCNs that you'll have to know. But you could at least try the free version.
As far as a kill command goes, just make sure to disable that in the radio codeplug and do everything you can to ensure the radio will not transmit.
