Monitoring issues GRE 500
dwayne0564
Xenia, Ohio
I have a GRE 500 and a Pro 197 scanner, In my area, they are broadcasting P25, ii reproadcast on on 800mhz . The Pro 197 receives broadcasts fine, but the GRE 500 is garbled, using the same software to program both. GRE is fine one minute and garbled the next, the Pro 197 never does this, any suggestions.
If it is a software issue, what then, GRE is out of business.
Thanks..
ScannerSK
Weld County, Colorado
Have you tried swapping the antennas being used on each scanner?
Have any of the advanced settings been changed in the GRE PSR-500 that you are aware of?
Shawn
ScannerSK
Do you have the latest firmware updates for the GRE PSR-500?
When you hold down the "3" button when turning on the scanner what do you see? It should like something like the following which is what my scanner is presently showing:
uP Appl Ver:U2.1
DSP App Ver:U1.4
DSP Voc Ver:F1.0
Shawn
dwayne0564
Xenia, Ohio
GRE 500
Have tried several antennas , even the outside one, did notice that up app version is 1.9 the DSP App and the DSP are 1.4 1.0
Where would I get the latest firmware update, since GRE website is closed up.
ScannerSK
Due to the number of requests for the PSR-500/600 firmware, I created a Yahoo Group to temporarily host the latest firmware.
The last offical GRE updates for the GRE PSR-500/600 scanner can be downloaded from the following website:
https://groups.yahoo.com/neo/groups/GRE-Scanner-Firmware/info
Click "Sign In" in the upper right hand corner.
Username: GREScannerFirmware
Password: Gre12345678
Click on Files tab to download the file(s).
Please sign out when you are finished so the next person can sign in when you are done.
Shawn
