Monitoring the full Database on the 536HP
dispatcher812
Connecticut
I was playing around with my scanner the other day and wanted to try the full database with my range set to 0. Not soon after I started to receive the weather frequencies. I would lock out one and get another. No where in the scanner is there, at least that I could find, to unselect the weather service and I did not see any option for that in Sentinel as well. Any ideas?
phask
zanesville
Look under your Nationwide settings. There is a LOT of CRAP in there you should probably turn off - including WX.
phask
zanesville
Ok thanks, I will try that. Cant that be done in Sentinel?
Yes - go to any Nationwide setting, under any , state, county and avoid them.
I think there may be another setting also - I'm on a HP1 - similar but different.
UPMan
In Memoriam
Arlington, TX
Some portions of RRDB also have the local weather channels listed. This is really in error (and a legacy from before the Nationwide channels were added to RRDB). I believe that, under current RRDB guidelines, they would not be accepted. But, someone needs to report the channels to be removed in order for them to be removed.
phask
zanesville
That explains why I have had them pop up, with associated curse words, when traveling.
UPMan
In Memoriam
Arlington, TX
Hmmm. Perhaps I stand corrected...I just did a full RRDB search on each of the standard NWS frequencies, and came up empty. Anyone see this happen, try to get the channel details for me (of course, if you have National DB "National Weather Service" turned on and "Federal" service type enabled, it will be stopping on the transmissions because you basically told it to...).
mikewazowski
Forums Manager
Oot and Aboot
I remember going State by State removing all the WX channels. It would surprise me if any were left.
The only entries left that the Home Patrols should be seeing are in the Nationwide databases belonging to a few different countries.
AK9R
Central Indiana
Paul, I've had this happen with my 536 while scanning from the full database. I think the last time I saw it, I had entered 46112 for the ZIP code with the default range and service selections. Not sure I can reproduce the problem, though.
phask
zanesville
As I said - I have seen it, but it's been at least 2 years. I think it might have been a Canadian WX - or maybe MI. Then it could have been a Coast Guard rebroadcast. Hard to tell when mobile.
UPMan
In Memoriam
Arlington, TX
They are part of the Nationwide Database. Easy to turn them off in the scanner.
