Monitoring uhf trunked systems
mikext
I'm trying to monitor Norfolk Naval Bases and Norfolk Naval Ship yard uhf trunked systems using a pro-96 to track the system. I can manually get the control channels with the system id, But unable scan and track the system id's. Help!!
Thanks, Mike
RagnarD
In a valley that only a few know where it is
Hi Mike,
I assume you are using a custom table correct?
Attached is a snippet of an old WIN96 file of mine that I used for NAVSTA and NNSY.
HTH.
73
de
chris
kq4z
  • NAVSTA061008.zip
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Mike,
If you aren't using Win96 you need to set the trunking tables.
In the bank(s) with the system(s) press PGM>TRUNK>FUNC + 2
Key in 406.0000 base and press ENTER
Key in 380 and press ENTER
Press DOWN button to 12.5KHz and press ENTER
FUNC + 3
Press DOWN button to Table on bottom line and press ENTER
SCAN
mikext
UHF Trunked systems
Frank, I followed your directions initally during the programming and nothing. My question would be do I need to enter all frequencies or just the control channels? This system has stumped me for sometime.
mikext
UHF Trunked Systems
Kq4z Thanks for the info, But I'm unable to open the zip file.
fmon
Eclipse, Virginia
Just the controls. The normal control is 406.7250 for NOB and is currently active. 408.5250 is normal and currently active for the Shipyard.
mikext
UHF trunked system.
No my PC won't open any type of zip file. I have both CC for NNSY and talk id's entered CC are set to motorola mode and still nothing.
fmon
Eclipse, Virginia
What does the CC display on line 4 when you manually park on it?
