Monroe County?
Thunderbolt
Global Database Administrator
Ann Arbor, Michigan
In a sense, this is history in the making. I remember when Monroe County use to be on 37.12 MHz. for their main Sheriff Dispatch and 37.10 MHz. was used for "mutual aid" purposes with all the adjoining counties. Back then the keyword was frequencies; today it's all about talkgroups! :)
73's
Ron
rdale
Lansing, MI
"Is anyone else getting anything other than 866.800? It seems to be the sheriff's dispatch... or am I just getting minor things because I don't have talkgroups programmed yet?"
If you are getting frequencies popping up you have not programmed the scanner correctly... You want to program it as a trunked system, check the FAQ's from the homepage here if you need more info.
Since it just came online a few hours ago with sheriff you aren't going to be inundated quite yet - you'll still need the VHF/UHF freq's plugged in until the conversion is complete.
- Rob
copsreporter
Monroe, Michigan
Thanks Rob.
I think I have it programed correctly, because it pops up as P25 when the freq. pops up. I just think they need to get the kinks out and I need to be more patient. I'll run through that help section to be sure though.
dan
rdale
Lansing, MI
Again - a frequency should not be popping up. The talkgroup ID # 2173 is what should be showing...
AAFD
monroe county 800mhz
they are on 460.175 and 866.3000 at the same time they told the sargent to go to tac 460.275 he was there but it did not come across on 800mhz.
thanks
AAFD
58 law1 on 866.3875? a house fire in carleton the deputy on scene says its his brothers house and its arson .
feta92
St. Clair Shores, MI
Has anyone been able to do some range testing of their own? I live on the eastside of the city and was wondering if I am going to be able to monitor Monroe county out here or just dont bother programming the scanner for that.
KB8UYC
Ypsilanti Michigan
Re: monroe county 800mhz
That would just be a voice channel....the only Control Channel that the system is using right now is 868.9000 and it is now T212........there are only a couple of the Sheriff units that are physically using MPSCS the rest have no capabilites right now which is why they are patching 460.175 and 58P911
Fire will remain patched like that for a while(I think they said for 1 year)
and for the most part the system sounds pretty good up here in Washtenaw County near the Wayne County Line, it could be better but it is fine now........
but is it not nice to finally hear them??
I heard this morning that someone is having radio problems and it is constant, they are on the way to CID in Livonia......CID is aware of their problem and waiting for them
Eric
WTFD10
Where the Buckeyes meet the Wolverines
Monroe Evening News article
New radio system going online - 12/13/2004
http://www.monroenews.com/articles/2004/12/13/news/news03.txt
The 800 MHz radios will be phased in and the conversion should be complete in February, officials said.
By ANDY ROGERS
A new local emergency radio system went active today, the first part of a phase-in that could convert the entire county over to the 800 MHz radio platform by the end of February.
Sgt. David Thompson of the Monroe County Sheriff's Office said this morning the system has joined the Michigan Public Safety Communication System - an assembly of 800 MHz radio systems located throughout Michigan.
The assimilation means Monroe County law enforcement will begin using the new signal today as radio installation crews replace the radio devices in squad cars with new 800 MHz-compatible units. That process will last until early next year, Sgt. Thompson said.
"Today they are going to begin switching out the mobile radios that are in the patrol cars, starting with the small police agencies," Sgt. Thompson said.
Also expected today is a report of coverage testing performed on the system in November. Sgt. Thompson said results of the testing are generally good, but there are some areas of the county that did not pass the testing. Many of those areas were located around Bedford Township.
"The system isn't going to be perfect, but once we get all of the kinks worked out, I'm confident that it will be a huge advantage to the county," said Sgt. Frank Atkinson of the Monroe County Sheriff's Office Traffic Services Division.
Throughout the entire county, however, the system exceeded the 95-percent in-building coverage requirement, he said, The state requires a radio signal strong enough for transmissions to penetrate the buildings of a particular construction grade. In some instances, Sgt. Thompson said the system might have failed the test in particular areas of the county because buildings of a heavier construction type were selected for testing purposes.
"There were some grids down in the Bedford area that failed," he said. "We went into some of the buildings that were probably (heavier construction type) and tested and it didn't work," he explained.
"We were only allowed to test one spot within a grid, so we could only select one building, so I'm putting together a list of the places that we went into and tested in."
He will compare that list to a map of grid cells where coverage testing revealed deficiencies.
Once Sgt. Thompson receives the final testing report today, he said a new wave of tests would be scheduled for the area to better determine the radio system's performance there.
He likened the new 800 MHz signal to a cellular phone signal that may work inside some buildings, but not all buildings.
Initial testing data shows the system achieved a 97-percent rate of success. Among 1,244 5/8 mile grid squares tested throughout the entire county, 1,211 passed coverage testing and 33 failed - a rate that exceeds the state mandate of 95-percent in-building coverage.
Until the transition of all county radio terminals to the 800 MHz system is complete, the current emergency radio system will be used simultaneously with the new system.
"Central Dispatch is going to patch the main (800 MHz channels) of the new system with the channels that we use in the existing system, so when an officer calls Central Dispatch, it doesn't matter what system they are using to call," Sgt. Thompson said.
"Central Dispatch will be able to hear you and the officers, it doesn't matter what system they're on, they'll be able to her the transmission."
Channels that will be patched over on both systems will include the City of Monroe's main emergency channel, the Law Enforcement Information Network (LEIN) channel, the county's main fire frequency channel and the outgoing Central Dispatch channel, he said.
Sgt. Thompson said installation of the new 800 MHz terminals in emergency response vehicles could be completed by the end of February.
AAFD
well i hope they dont try the middle of miejers i took the scanner in and could not hear a thing.
KB8UYC
Ypsilanti Michigan
Remember this though: Motorola Radios are way different than a scanner, scanners are no where near as sensitive as Motorola Radios. I can hear things on my motorola prep that my scanner cannot hear!
Eric
rjschall
Thunderbolt said:
Monroe Central Dispatch recently moved into their new center located at the Monroe County Fairgrounds.
--I know this post is old, but since when did they move to the fairgrounds and where on the grounds are they??
