The freq I mentioned was full on with some sort of data, but not a control channel per se. Perhaps it was a test.
It's a test pattern for talk-out bit error rate testing, very typical with Motorola ASTRO 25 systems during the coverage acceptance testing phase.I am getting a strong signal on both 769.30625 and 770.30625. It is a pulsing white noise sound on both. It sounds sort of like a CC data stream, but it is not.
PS - Minor correction for the East cell: 769.30626 should be 769.30625
I've seen a presentation by a Motorola project manager that described the process. It basically uses a laptop with loaded with proprietary testing software, a "golden" mobile radio that has been precisely calibrated, a mag mount antenna, and a GPS antenna. A team drives through the system footprint to test every grid square to verify the BER that was specified in the contact. The software senses when it is a new grid square, initiates a test sequence, and records the result.
A friend of mine is saying all Montgomery county will be encrypted including fire we will no longer be able to hear Montgomery county
