Mosfet RF mod
elmanoduarte
Hello.
Could be possible to mod or change the power 25w mosfet from a Motorola GM 340 or a GM360 to a mosfet for 50w rf output ???
prcguy
Hello.
If the device parameters are similar and the higher power FET is rated for at least 3dB more gain then maybe. If the new FET has similar specs and the same or less gain then you won't get any more power out.
elmanoduarte
Hello thanks.
Well.. in fact I do have an GM340 and an GM360 model... both 25w RF output.
So... I do not know even theres any GM models or compatible or not with more watts... even 50w !
