Mosque frequencies
Davethepitch
I hope I can ask this question but what frequencies do the mosques use I have been looking for them especially Stoke on Trent area.
I have found one but I cannot hear anything
Dave
Dave
I'm sure some do most don't, the frequencies could be any where, licensed by the FCC or not, low powered VHF MURS, FRS, GMRS, licensed UHF, rented or owned radios on local systems. They could be analog, NXDN, DMR, basic encryption, advanced encryption, even in the clear. Best suggestion is take a scanner with spectrum sweep/close call and sit across the street from the Mosque, especially on a Friday, and see what you hear.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Likely in the same range as the one you have found. Did you store that frequency?
Davethepitch
Hi I am going to store it tomorrow in my 8600 mk2 and if it is a correct frequency I will then add it on my 8200 mk3
Dave
paulears
Lowestoft - UK
Some are technically assigned ofcom UHF, but look in all the business bands where people can licence on line simply. For interference reasons, many get plonked in 453-456. the london area had these frequencies, but theyre a bit old now.
Ch1. 454.39375 MHz, 12.5 kHz ch.sp. (0.5 to 5 watts TX systems)
Ch2. 454.40625 MHz, 12.5 kHz ch.sp. (0.5 to 5 watts TX systems)
Ch3. 454.79375 MHz, 12.5 kHz ch.sp. (0.5 to 5 watts TX systems)
Ch4. 454.80625 MHz, 12.5 kHz ch.sp. (0.5 to 5 watts TX systems)
Ch5. 454.02500 MHz, 25.0 kHz ch.sp. (5 to 50 watts TX systems)
Ch6. 454.05000 MHz, 25.0 kHz ch.sp. (5 to 50 watts TX systems)
Ch7. 454.07500 MHz, 25.0 kHz ch.sp. (5 to 50 watts TX systems)
Ch8. 454.10000 MHz, 25.0 kHz ch.sp. (5 to 50 watts TX systems)
Ch9. 454.12500 MHz, 25.0 kHz ch.sp. (5 to 50 watts TX systems)
Ch10. 454.15000 MHz, 25.0 kHz ch.sp. (5 to 50 watts TX systems)
Ch11. 454.17500 MHz, 25.0 kHz ch.sp. (5 to 50 watts TX systems)
Ch12. 454.25000 MHz, 25.0 kHz ch.sp. (5 to 50 watts TX systems)
Ch13. 454.27500 MHz, 25.0 kHz ch.sp. (5 to 50 watts TX systems)
Ch14. 454.30000 MHz, 25.0 kHz ch.sp. (5 to 50 watts TX systems)
Ch15. 454.32500 MHz, 25.0 kHz ch.sp. (5 to 50 watts TX systems)
Ch16. 454.35000 MHz, 25.0 kHz ch.sp. (5 to 50 watts TX systems)
Ch17. 454.70000 MHz, 25.0 kHz ch.sp. (5 to 50 watts TX systems)
Ch18. 454.77500 MHz, 25.0 kHz ch.sp. (5 to 50 watts TX systems)
Ch19. 454.78750 MHz, 12.5 kHz ch.sp. (5 to 50 watts TX systems)
Ch20. 454.82500 MHz, 25.0 kHz ch.sp. (5 to 50 watts TX systems)
alinicoll
Powys, UK
RRUK has listed a number of these frequencies. Often when travelling the UK I do find that frequencies are shared with another user and are not listed on RUK. Not band specific.
