KampingAnthony1AolCo
Hello I wanted to see peoples opinions on which radio they like the best and you can give your options on the radios also if you want. You can say why you like that radio and why you choose it.
The Unity is incapable of doing the 3600 CC Motorola trunking system.Just trying to learn more about multi-band radios:
So the Unity can NOT perform MOT P25 trunking - correct? If that's the case, agencies that are using it are only using conventional? or does it do another type of trunking?
<thanks for educating me>
Thanks for the additional.
My local agency is converting from an 800mhz Moto Smartnet type II to a 7.x P25 system. Is that something Unity would handle or is this the 3600 CC Moto you're referring to?
How many zones (total) does the Harris Unity have? I have searched the technical spec sheet, but can't find it.Like radiomankc, I have owned all three radios: Unity, Liberty and APX and seem to carry the Unity more also.
At first it seemed very foreign to program, but luckily I had just retired from the "green" world and had used PRC-148's and 152's, 117's for quite some time.
My first thought on the three radios were as follows:
APX-7000, why do I have to choose 2 bands? For this price, I want three bands.
Thales Liberty, heavy and feels like a commercial MBITR, but has a full keypad.
Unity, I like the large display, but this thing feels like it will break the first time I drop it. The plastic covers on the top and front display stayed on for the first 6 months or so as I felt it was adding some protection to the radio. After the first drop on concrete, I felt better. One small scratch, a splash in the water, and everything still works. (I work on ships near water, so IS rated and water resistance are a must.)
Now, I have an older VHF Astro Saber, and a Harris Unity that I use very often. The others were sold off, traded for other models and not used very much.
As for ham radio use, Motorola is very good as once you learn to use the CPS, it doesn't change very much.
The idea of "mission plans" in the Unity, drives me nuts after programming a pile of Motorola handhelds. But once, you do it a few times, it gets easier.
With piles of Motorola equipment on auction sites, that is what I recommend for amateur radio use.
If you need it for work, have your employer pay for it and buy new gear. In my case I made a deal with the local radio vendor on a Harris Unity that I use for fun and work.
Harris radios don't use zones in the same way that motorola does. You have systems, groups and in the case of the Unity series you also have zones and mission plans. The Unity portable supports 1,250 channels/talkgroups per mission plan. The Unity (like any Harris radio) requires that all systems (analog/P25 Conventional/P25 systems) in their own "system". These systems appear in the radio the same way as a zone would within a motorola radio. With that said it also allows you to create zones above and beyond the systems as a way to mix systems into a single ramp. I do not believe that the number of zones is limited. Since it also hold mission plans (multiple personality files) you can have a total of 12,500 channels/talkgroups per radio.
I have been playing with the APX7000 VHF/800 quite a bit the last few weeks and still prefer the Unity. What I can say is that audio is louder on the APX and the audio also has more bass.
For the Unity, just program a side button for nuisance delete - no need to go into a menu.I like the one button push scan channel temp delete on the APX & Liberty....the Unity you have to go in the menu and delete.
Actually, bottom side button using firmware 4.3.11 on an analog channel. I don't think there is any trick otherwise.Thunderknight,
Have you actually tried this or are you just guessing? We tried the side button programmed for nuisance delete. Our radios won't do it with the button programmed for it. If your radio does work what is the tick to programing it it beyond just programming the button function?
