Motorola bandwidth&filter setting
I have a xts3000 wander what settings would be best 7.8 filter or 5.6. 12.5 or 25 khz settings using it to listen to a mixed mode system p25 phase 1 and analog 800mhz
Anderegg
Enter text in this field
San Diego
My county programmed 800Mhz radio is set to 7.8...I believe that 5.6 may lower receiver sensitivity slightly, and should only be considered if you are having interference issues with very close adjoining frequencies...in other words, 5.6 is a "fix" for a "problem", that if you are not experiencing, should not be necessary.
Similarly, unless I am mistaken, the 800MHz spectrum is still using 25Khz bandwidth for analog, even though a mixed mode system would be using 12.5 when spitting out P25. All P25 is 12.5, so setting the system to 25 would not alter that.
Paul
Thanks 7.8 sounds better on analog 5.6 sounds More flat they sound over modulation a bit at 12.5khz bandwidth 25khz bandwith sounded more full but now with p25 the 12.5 bandwidth sounds better. The 25bandwidth they sounded way to lound like they was eating the mic the 5.6 filter they sounded more nasel so 7.8 works better for p25 even tho mix mode system they will soon first of year going p25 for everyone
IAmSixNine
Dallas, TX
Quick question. Do you mean a 3600 baud digitial system? Phase 1 and 2 P25 are 9600 baud and the XTS3000 is not capable of that.
It is capable of 3600 baud which was the first version of digital.
Im also not aware of any Phase 1 system being analog compatible.
However 3600 baud digitial systems were backwards compatible with analog 800 stuff.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
The xts3000 is capable of p25 trunking with very specific firmware and flashcode on the 800Mhz band.
IAmSixNine
Dallas, TX
Nice.. I knew there was an odd version out there that allowed it.
Guess i also learned something new, never seen a P25 Phase 1 9600 system with analog on it.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
and that's something you'll never see.
The OP's post is quite confusing.
Yes, an XTS3000 will do 800Mhz P25 trunking with the right flashcode and firmware.
No, there's no such animal as a P25 trunking system with analog.
Until he responds and clears this up, his initial post is very confusing.
IAmSixNine
Dallas, TX
Well thats what i was originally thinking in post #4.
There was a local system that was Type 2 trunking with analog and digital talk groups, but it was 3600 baud, not true p25 9600. Phase 1 or 2. Glad to see im not loosing it.
Anderegg
San Diego
For future reference equalizer, "P25 Phase I" wording is reserved for 9600 baud FDMA (non TDMA) digital only trunking systems. ;-)
Paul
