Motorola CDM1250 CSQ/Monitor
SFD1117
Shelton, CT
What exactly does the monitor function do and is it recommended to be turned on?
bezking
On the Road
Monitor disables the PL tone and opens the squlech so you hear static. This feature is to be used when you are hearing a very very weak signal or you want to temporarily stop the radio from needing the correct PL tone to pass audio.
Don't leave it on all of the time though, when there is no traffic, all you will hear is static.
SD70MAC
NC
monitor
You can also set it up to be silent so you don't hear the static. Lots of fire departments have it set up as silent to drop the PL tone when you using a channel like NC State fire(154.280) when needed . Most counties in NC have this but use different PL tone for each county and you drop the PL when you are training with another county if needed you have that option.
Skypilot007
Medford, NJ
The monitor function on the cdm's only disables the PL tone. It doesn't open the squelch. At least not on any of mine. You can program a button for the "open squelch" function if you like to hear some staic.
bezking
On the Road
That's interesting... On my HT1250 you can select what the MON button does - either open the squelch or just disable the PL
