Motorola CDM1550LS can read but cant write
kanablecb
SW Wisconsin
Have a CDM1550LS+ mobile. proper software and cable with RIB. Can read radio fine, but when I try to write it give a message saying its not in the narrowband protocol. All channels are 12.5. It also puts radio in TEST MODE instead of program mode. Thoughts appreciated. Thank you.
KevinC
Other
Home
Try deleting all references to Passport trunking.
jeepsandradios
East of the Mississippi
I don't think you can delete all trunking stuff. There is one there by default. Most likely that's your issue. Just change the frequencies to narrow. At least that's the case on the CDM1250LS+.
Also it should show up as invalid fields
