Motorola Quantar Intellirepeater Single Site-VOC Configuration
ncicchino
West Caldwell, NJ
Hi All,
Wanted to ask if anyone here has experience on setting up a single-site, voice on control channel configuration on a Motorola Quantar using the Intellirepeater system type, along with the correct APX programming fields. I have been testing different configurations and have not been able to successfully configure this. I receive an Out of Range message with my current Type II configuration.
My understanding after reading documentation is that this is possible, and would typically be used in a condition where a site could not be part of a SmartZone network for which ever reason.
I'm looking to explore this for private use instead of my current Astro Conventional configuration, enabling different talk groups to be leveraged. I am aware that if a talk group is in use another will not transmit, which I am perfectly fine with.
In order to keep the frequencies private, I'll use the pair below for example only. I can put the different repeater configurations I have tried if necessary, but in effort to keep this post short and sweet omitted it for now.
TX: XXX.5050
RX: XXX.4000
Thank you all in advance for your help and thoughts on this!
N4DES
Retired 0598 Czar ÆS Ø
South FL
If you are in VHF or UHF you will need to review your FCC license carefully. If there is any doubt you will need to talk to a coordinator to make the necessary adjustments to your license before you make any technical changes.
