Motorola CPS Corruption
BlueDevil
WA
Has anyone ever heard of corruption of the Motorola CPS programs?
jhal94
Pinellas County, Florida
Any software can become corrupt, even straight from motorolas website. Software is software it doesn't matter where it came from unless it's been altered. Now then, in what way was it "corrupted"?
MTS2000des
5B2_BEE00 Czar
the difference is, when you download "corrputed" software off MOL, you can open a support ticket, and get it fixed. You also get the benefit of a CD/DVD being sent to you via FedEX.
You see, when you actually subscribe to the software, you get the ability to get support. Something you don't get the benefit of with bootleg software downloaded off the internet. :wink:
PACNWDude
I have had Motorola CPS software corrupt from their website. Copies on disc fail and have had radios that sat on the shelf unused for a few years corrupt their codeplug.
The codeplug was loaded into the radios and then they sat not being connected to a power source. This was with newer Vertex Standard VX-4200 radios after Motorola bought them and changed the software.
I have had Maxtrac and Saber radios on the shelf for years and still have their codeplug intact.
BlueDevil
WA
I am not sure if it is corrupt or not. Using the same cables and the same radio with the same version of the software I can successfully program the radio on one computer but not the other. I believe I have it narrowed down to software corruption, serial port/hardware failure or both.
Any thoughts?
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Any thoughts?
Are both computers running the same version of Windows? If one is Windows 7 64 bit or Win 8, and the other is neither, that may be your answer right there. A number of different CPS's for various radios choke on these two. Some will also choke on Win 7 32 bit, and some don't even like Vista.
This issue is well documented here and on the batboard ever since Win 7 came out.
PACNWDude
Both Win XP, one works but not the other. You can go to Hardware Manager and see if the com port is set to COM1 on the non working computer. Otherwise there could be something wrong.
That version of CPS should be fine on XP. The newer CPS version address problems with Windows Vista7/8 compatibility problems.
Many Motorola service shops are buying up XP Pro computers as radio programmers since they work better than Vista/7/8.
BlueDevil
WA
Well here is some more information to add to the discussion. I was able to successfully program my Motorola XTS2500 with the ASTRO25 Portable CPS. I was also able to program my HT1250 with the Professional Series CPS.
I am beginning to think more and more that my Commercial Series CPS along with Radius Series RSS must be corrupt. Neither one of these programs will allow me to program a radio using this computer.
I have tried uninstalling and re-installing...
BlueDevil
WA
Still having issues. I have tested the serial com port and it seems to be working normally. No lose pins and I have been able to program other radios using other software to program them. I am thinking that the problem has to be isolated to the software itself.
The Commercial Series CPS gives me the Error #768 code when attempting to read the radio. It gives me this code whether I have the radio and cable hooked up or not. This also leads me to believe that the CPS is not able to communicate with the Serial Port. I have confirmed that the correct port has been selected and any other obvious troubleshooting issues. This seems more advanced!
com501
What VERSION of CPS?
What VERSION of Windows XP?
IS this a HARD PHYSICAL serial port or a USB to serial adapter?
Are both computers the same brand or motherboard manufacturer? Laptop, desktop?
Have called the support desk to inquire what the error 768 means yet?
BlueDevil
WA
I am using several different CPS programs for multiple different radios. The Commercial Series CPS is R5.16. The Radius 1225 Series is R04.00.
I am using a true serial port on the laptop running Windows XP SP3.
Like I said I have successfully programmed all these radios before. It was only until recently that something went wrong with the software and I cannot program these radios.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Have you called Motorola? The one time I had an issue they were very helpful.
BlueDevil
WA
I just got off the phone with them and they claimed it was because I am using a USB cable. The fact that I have been successfully programming multiple radios prior to this and still can using other computers didn't seem to interest them. I think I must have something messed up in the registry files. The root cause is obviously deeper than just uninstalling and reinstalling the software.
cmdrwill
So Cali
Windows has been known to steel resources from applications like CPS. A USB is one resource that gets screwed up.
cabletech
Puget Sound
Current version for commerical is 5.18, ver 4 is not only current but is also the last for the 1225.
brandon, we talked about what you need to look for but you have not sent me the information, so behond this I think I am out.
RodStrong
West
Not too long ago I had an issue with freqs above a certain range (still within the radios' range) that would receive but wouldn't transmit on a few MCS2000's. After a ton of drama and eventually sending a radio in for inspection, I was told my software was corrupted. I got some fresh software and they are working fine now. Only time I think I ever had "corrupted" software, and I don't know what caused it.
