Motorola CPS Error#1224
18a101
I am new to using Motorola CPS. I have written to some other models or radios without problems. I am trying to write for the first time to a different model and am seeing the following error.
Error#1224
Unable to write/clone. The archive contains settings that require the Canada Full Frequency Range feature to be registered in CPS.
Does anyone know where or what setting I need to turn off to make this error go away. I don't need the Canada Full Frequency Range...
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Sounds like TRBO radio with frequencies in the upper 860MHz region?
Delete those and you should be fine. You can probably look at the help file in CPS to see the exact range.
If you are located in Canada and need those frequencies, you'll need to purchase the entitlement from Motorola.
