Motorola CPS PLUS programming using RS232
Kader
Hello, I would be grateful if someone could told me, why i cannot detect Radio via RS232. Knowing that I am using adapter USB to RS232 and I have already selected the right port ...
natedawg1604
Colorado
What type of USB - Serial adapter do you have? Does it have an FTDI chip?
Project25_MASTR
Millennial Graying OBT Guy
Texas
What type of radio are you trying to program? On the the screen shot is see this may be a CPS used for Motorola's tetra line of subscribers.
Sent from my SM-T713 using Tapatalk
Kader
Yes,it is Tetra Radio: MTP 8500
wardaddy
Go to Tools > Options and make sure the communications settings are correct. Once you do that, go to File > Read Phone. You will not be able to automatically detect the unit with the RS232 cable.
Kader
Go to Tools > Options and make sure the communications settings are correct. Once you do that, go to File > Read Phone. You will not be able to automatically detect the unit with the RS232 cable.[/QUOTE
Do you have and idea about communication setting how it should be configured ?
wardaddy
Select the appropriate COM port and set the speed and you should be all set.
wardaddy
It will never automatically detect that radio with that cable. You have to set it up manually and then read the radio from the file menu (it will say "read phone"). Otherwise, you will just have to get a USB cable.
Don't those Tetra radios also have to be put into programming mode as well?
Kader
Yes, it's in programming mode. Unfortunately it doesn't work with rs232 . With this cable you have more features for example when you have damaged firmware Radio you can repair it just with this cable
Kader
Now I am getting this error shown in print screen . About the cable , it is original one I have bought it from Motorola .
