motorola ex600
ch-24
brooklyn ny
i am having difficulty with my ex600 it only shows the id of some radios even when i hear a chirp it wont display the id and i know it has to be another motorola. the other radio i am using for the test is a ex500 the only thing i can think of is that i programmed the radios wrong but i tried changing all the settings around to see if it will fix the problem but nothing seems to work
there is another problem when i want to send out an alert to one radio my radio does not let me use the number keypad to put in the id number if anyone knows how to fix that problem it would be great
(btw this problem that i am having is using the mdc signaling feature)
33kracing
grand island, ne
are both radios using the same ID? I knw this because I have tried this before and if both radios use the same ID... when u transmit or de-transmit, no id's will show up on either radio. as for the latter part of your post... someone with a moto college degree will help you on that one haha
ch-24
brooklyn ny
Thank you
Yiu are correct i am using the same id on yhe radios thank you very much oh and i somehow maneged to get the number keys working i dont know what i did but it works thank you very much :)
