Motorola GM338 programming
GMEMan
Hello everyone, I'm having a bit of trouble with programming my Motorola GM338 uhf 450-525MHz. I can edit/ change the frequency of the current channels but I cannot add anymore channels, I've only got about 20 channels and there's something like a 125 channel limit so it should be able to fit more channels in. If anyone knows how to fix this issue or has had this happen to them, can you please let me know .
Sent from my iPad using Tapatalk
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
We really need more information that this to even attempt to give you a useful answer. You will notice from previous threads asking for programming help that this is essential.
Model number, please.
CPS part number, region, and version, please.
Are you having problems adding additional personalities or adding personalities to a zone?
GMEMan
Hi there the model number of the radio is AZM25SHF9AA5, the version of CPS is R06.12.02 and it's an Australian version. I'm having problems adding new personalities but I can edit (change frequency/alpha tag ect) of the current personalities.But I cannot add a new personality. When I try to add a new channel is appears to work fine on the CPS but when I write it to the radio, only the existing channel are there.
