motorola gp1280 problem
jortsun
sevilla (spain)
Hello. I have a Moto GP1280 UHF Mobile type MDH25RDN9CK8AE, i have software but no codeplug and when i try to read or write to the radio i can not, it displays on the radio screen on power on, "EEPROM CKsum" radio failure
Can anyone help me, thanks.
fineshot1
NJ USA (Republic of NJ)
If you had a previously saved codeplug you might be able to recover by writing it to memory(if it would take) but since you don't pack it up & send it to motorola as they will have to fix it.
fineshot1
There is no another way of obtaining the codeplug? I have the cable and programe. Thanks
You would have to obtain a codeplug from the exact same band and model radio
and even then it may not work. The possible solution is to keep trying to load the
codeplug over and over until it is successfully written to the radio however I have
tried this on a similar model and it was not successfull after several hundred tries
so off to motorola it went.
Skypilot007
Medford, NJ
Isn't the GP1280 similar to the HT1250 American radio? If so new CPS could revive the radio. The newer versions of CPS available for the CDM/HT professional series radios fixes this issue. I have been able to revive numerous HT's and CDM's with the CSEEPROM error. I would try to check into that before sending it to /\/\.
bezking
On the Road
You need to perform the "region hack" - search batboard.batlabs.com for "Pro Series Region" and follow the instructions.
fineshot1
CPS R06.11.05 or newer (available from Motorola) should fix it.
I am happy to report that the R06.11.10 cps fixed my EEPROM CKsum problem although
it took some tinkering around to get it to work right as there is no help in the help file on how
to use it.
If you have an archived codeplug file open it up and try and write it to the radio.
You will get a cps warning that the radio data is corrupted and it asks if you want
to correct the problem with a default or a archived codeplug. I selected the default
even though I should have selected the archived. The cps immediately wrote the
default codeplug data to the radio and the radio recovered partially.
Then I reopened the archived codeplug and tried writing that to the radio. At first it
did not take but I kept trying and it eventually successfully wrote the archived data
to the radio and I confirmed the radio was fully functional after checking it on a service
monitor.
Excellent - less shipments to moto for these kinds of errors.
