Motorola GR1225 Repeater
top13
SE Massachusetts
Hi All,
Can the GR1225 be programmed to scan the programmed channels?
Is there a radio shop in Eastern Massachusetts that can reprogram this repeater?
I don't want to ship it. Bouncing around in a UPS truck does don't help repeaters.
prcguy
If the radios used in the GR1225 scan I think the only way you can make use of that is to have a scanning receiver and a fixed transmitter, there is probably no way to sync the two radios onto the same channel when scanning. You will also be limited to the band width of the duplexer which can be about 200KHz wide for some flat pack mobile types.
