Motorola maratrac Radiohead pinout
Redryder28125
So I recently bought a old center console that came with a radio head untested so I did my research and got a Motorola maratrac radio trunk unit and the only issue is the connection for the back of the head is cut and just loose wire, I don’t mind putting new connections on it to make it work but I can’t find a pinning diagram anywhere to know where to plug them in on the head itself, I’ve tried to post a picture of the wire but it says the file size is too big so
ff026
ff026
The numbers are in the back of the head. What head do you have. Those only connect to the clamshell heads.
Redryder28125
I’m not sure the difference between heads I’ve never worked with radios let alone Motorola but this is the head unit I got
ff026
ff026
That cable is not for that head. That’s is the A7 head and uses a completely different cable.
This is the head that you would need for that cable.
jeepsandradios
East of the Mississippi
Correct, either search ebay for a different cable or another head. Those 2 do not go together. I used to maintain a fleet with hundreds of those clam shell heads....it was a disaster. Definately dont miss those pins.
Redryder28125
I don’t blame you, I do mostly light up fitting for local volly firefighters and just got around to installing a B/W lightbar on my own vehicle just for the fun of it and I had to wire a 24 pin connector into a 12 wire switch box and it wasn’t very fun I much prefer the newer stuff but does anyone know a part number for the cable I need or what to look for on eBay
ff026
ff026
Found one on eBay.
