Motorola mts2000 programming
roee
los angeles
Hey, I'm trying to program my motorola mts2000 radios and I need to generate a system key for the radio but I do not know how. Is there a website or program that I can use to generate one?
cmdrwill
So Cali
We need more information. Are you wanting to program a trunking system in your radio?
Programing the MTS2000 for conventional systems does not require a 'system key'.
roee
los angeles
Motorola mts2000
It's not being set up for trunking. I tried every possible way of programming it and something is missing the software does not let me proceed
Make sure you remove any old trunking personalities and systems that are in the radio. If all else fails, see if you can find a codeplug from a non-trunked system MTS2000 with the exact same model number and push it in.
MTS2000des
5B2_BEE00 Czar
Is the CPS prompting you for the Advanced System Key (ASK)?
If so there is no way around that. If the original owner wrote to the radio with an ASK, then it will ask for that ASK to be attached even if you want to program conventional channels.
The ASK implementation is a one way street in the MTS/MCS world. There are ways to remove it, but it requires advanced tools and techniques that are beyond the scope of this forum.
