Motorola RSS Spectra Software
MatthiasTHM
Watertown, SD
Hello everyone!
I have been looking everywhere I can to find the Motorola RSS Spectra programming software, but I can't seem to find it. Where could I find the software?
Thanks!
MatthiasTHM
mtp850
Motorola RSS Spectra software is now over 40 years old. You will find out that it is a much bigger issue to make it work on today's computers than finding the RSS itself.
MatthiasTHM
Watertown, SD
I’ve seen people program a Spectra on DosBox with a Windows 7. I just need to find the software and save it on the Toughbook. I’ve gotten the GM300 RSS software to work on the 7.
MTS2000des
5B2_BEE00 Czar
Spectra RSS may run, but you stand a good chance of bricking a radio if you actually try to write with it. These radios were in production when the average PC was a 386/486 and the first Pentium came out- and RSS was written for timing routines accordingly. Resurrecting these relic radios means using period correct hardware and software if one wants good results.
Echo4Thirty
Colorado Springs, CO
Listen to this advice. You may be able to read it just fine and may be able to write it. Others have had success. But and this is a HUGE but, this software was written for very specific CPU clock speeds and bases its communication with the radio on those speeds. It also looks for a real serial UART. We still keep a 486 machine in the back with pure DOS 6.22 for the twice a year we need a DOS machine.
We have also bricked MANY a customer radio on dosbox and windows 7 machines. We have also successfully programmed them on it. Our policy is to try to match the programming environment to what was used back when the radio was supported. This is why we have a real DOS machine as well as Windows 7 32 bit machines all the way up to current Windows 11 x64 machines.
mtp850
As most of the people here said already, without an ancient laptop with a mediocre CPU and RS232 serial port, it is still operational, even then we used a special piece of software called "MOSLO" that we ran before starting Spectra RSS in order to even further throttle down CPU clock speed.
wa8pyr
Lead Database Admin
Ohio
buy an old laptop from ebay. Motorola RSS Spectra didn't work on my dell D620 with or without dosbox. What worked was using a DOS bootable USB stick.
That worked for me too, on a variety of DOS RSS radios. I used Rufus DOS and copied the contents of my old 486 laptop over to the thumb drive it's on; works like a charm.
