First of all I'm no expert, neither on the Swedish Storstockholms Lokaltrafik TETRA system or TETRA in general. But actually there are two ways I know of to get to these group names in the previously named system.
One way is what Ubbe describes and can be seen below with the actual text in the bold red bits (yes you need both the start and the fragment). This is just standard 8-bit coded letters. To make life easy for you this decodes to >>>
Line-tg:69:#L 69:#H S-CITY:0; <<<
The biggest issue with Telive, well not exactly Telive but the attached osmo-tetra source, is that the experimental support for fragmented data is broken. To make life more complicated TETRA also can make use of PDU association, which needs to be disassociated before the individual PDUs can be processed from that MAC block. So there is also a chance to miss or mix up data parts in these fragmented SDS data with the Telive version of osmo-tetra. Newer official versions of osmo-tetra had these issues fixed, but instead are not plug-n-play compatible with Telive. TTT should overcome both these problems and get the full data, disassociated and defragmented. Haven't used TTT in a few years though so I can't comfirm. But also this SDS data is not standard "Text Messaging" but instead as "User application defined". Therefore it still won't decode despite being plain text. There are also a few different types of SDS data, where some contain these talk group names. You can copy-paste the
red data bits to for instance
this decoder and test the data yourself.
Oh right, I said two ways do get the names.. The other one is by the mnemonic element in the D-FACILITY PDU, but for now I'll leave that one for you to figure out yourself.
MAC-RESOURCE (fragmented), TM-SDU , TL-SDU
[0000000111111001000011110111110000111100000 01010 01001111010000000000000001111101001100100000000111101100000001001111001 01001100011010010110111001100101001011010111010001100111001110100011011000111001001110100010001101001100001000000011011000111001001110100010001101001]
MAC-FRAG, TM-SDU, FCS (32-bit CRC)
[0101 00000100000010100110010110101000011010010010101010001011001001110100011000000111011 0 00101100001010000010101101101100 1000]
MAC-END
[011100000111000000000100]
