SailorDan
BLUF: When building a low duty cycle repeater, are the challenges of working with older Motorola radios (software/learning curve) offset by significantly better performance? (compared to low budget Chinese stuff)
Use case: Portable GMRS repeater with ~30W out used to facilitate family connectivity during camping trips. This would be a low duty cycle application with possible battery operation and solar back up.
Discussion: Motorola radios are regarded as premium, commercial quality products - and priced accordingly. Used ones are available, but seem challenging to source programming software for, require archaic operating systems to run said software, and have a steeper learning curve to program (designed for commercial vs consumer use).
Retevis and Wouxun both have GMRS radios (RA87 / KG-1000G) that can link for repeater function, but they are likely not of the same quality as a M1225 or CM200. As a hobbyist, I think the consumer focused radios would be easier to program and adjust. They would probably also be more user friendly if I eventually break up and use a mobiles.
I do have a Retevis RT97 that has worked, but I feel is a little lacking at 5W. Since I am primarily repeating 5W HT transmissions, am I wasting my time/money looking for higher output. I currently use a portable 30' mast with heliax feedline. Would a Motorola option be less likely to desense and improve my receive? (Wouxun claims a receiver sensitivity of 0.3uv - which is comparable to a M1225)
$$$Cost: Would be about the same for both options, with the Motorola option possibly being a little cheaper.
Appreciate your thoughts - Dan
