Motorola XPR 2500 unresponsive
wau_et
Hello. I installed a programmed XPR 2500 yesterday. Tested on multiple channels without issues. Tx and Rx worked flawlessly. Today radio powers on and buttons are completely unresponsive. After 20~30 sec a continuous tone happens until radio is powered off. I have ensure proper voltage to radio. Also to note display shows icons I am unfamiliar with. The icons are:
Antenna (without strength bars)
A solid arrow pointing to the right.
A big letter H
Any help would be greatly appreciated.
Thanks Guys
K2NEC
NA
Are you able to attach pictures? Where is the radio held? In a car with fluctuating temperatures or inside?
Those icons mean that you are receiving a signal, on direct, and high power.
wau_et
No actually it was installed in a Gantry crane on a drillship. I have it in the shop in the pics.
80413
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I believe a tower with an arrow to the right means it's transmitting and if the green light is solid, that confirms it's transmitting. If the green light is blinking, it's receiving and blinking green twice is data or an encrypted call.
The H is High Power and the key with the slash through it means encryption is not available.
Direct is two vertical lines with an arrow pointing to the right between them. It's not on direct.
Was this on a Capacity Plus trunking system?
wau_et
No it is not on Capacity Plus.
I just don't understand the radio just becoming unresponsive. As stated above the radio was functioning fine Tx and Rx. Now nothing.
firefive76
Kansas
As mentioned above, the radio is stuck in transmit, hence the unresponsive buttons and the TOT after 30 seconds. Check your mic jack and accessory plug to make sure that nothing is shorting and causing it to be transmitting.
K2NEC
NA
Right. Wasn't sure about the direct so I gave it my best guess.
Does it do this on every channel? Or do you not have the option to change channels when you power up at all?
Did the radio write successfully when you programmed it last time?
wau_et
We can not change channels at all, Also It was programmed when it arrived on board. Almost like its keypad locked or something in that manner
N1GTL
CT
As mentioned, are the mic pins shorted? Hard to see from the pic. Also, check the accessory connector. There is a PTT line there which may be bent or shorted.
KK6ZTE
California
I've had moisture get into the mic jack (on a CM200d) and cause all kinds of weird issues due to corrosion.
