I have a Motorola XPR 4550 being used for Amateur Radio. It should output 25 to 48 watts according to the CPS and the model number. However, output power per a Daiwa Meter shows almost exactly half of the rated power on both Low and High settings on both analog and digital channels.
I've checked the voltage and used two different Astron power supplies with similar results. The channels that actually register 25 to 48 watts are the programmed Digital Simplex channels.
My antenna has low SWR and my Icom 5100 registers its rated power on the same meter.
Otherwise the radio works as expected.
Thank you for any help provided.
Nick
Nick
