XTL/XTS5000 Motorola XTS 5000 Clean Codeplug
KA4HJB
Looking for a blank/clean XTS 5000 Model III VHF codeplug template. Have flashcode 580008-000482-0. Just need something with no trunking systems so I can build from scratch using conventional. Happy to receive via PM.
KA4HJB
I read it out, but I got the radio used and it is junked up with a bunch of trunked systems that I can't delete without adding another to replace them, but I need a ASK/software key to add another. I decided my best route was to just ask for a clean CP.
KA4HJB
I tried, but the add buttons are greyed out. I think I need a ASK/Software Key.
n3obl
ØAES-1056
PA
If its hit with an ASK you will need unmentionable software to clear the codeplug. Period full stop.
It sucks that many of these radios end up in the used market from surplus with ASK still attached and basically useless unless you use certain "improper" software.
KA4HJB
Correct me if I'm wrong, but I thought ASKs only prevented me from adding/editing the trunking system the key is tied to. I can still edit everything, but I can't add any trunking systems to get rid of the old ones.
KJ4DHF
If radio was just purchased be time to send it back to seller if they did not disclose it had ASK implemented on radio. If you purchased the radio with ASK you need to do a ton of research and reading.
KA4HJB
It might not have an ASK then, because I can still edit conventional.
rescue161
KE4FHH
Hubert, NC
On your codeplug/feature set, you must have at least one trunking system in the radio. Just don't point to it in the zones and you'll be fine.
