Motorola XTS 5000 Double Chirp after transmitting
Hello all,
Just wondering what a double chirp means after transmitting on an XTS 5000 and should I be worried about it occurring. A video which is linked here: (XTS5000DoubleChirp.MOV) shows the double chirp in action after transmitting.
GTR8000
NY/NJ Database Guy
BEE00
It means the battery is dying...see the flashing battery indicator? Time to replace the battery, it clearly can't hold a full charge if it's going from "full" to flashing empty after transmitting.
Looking at the battery page on the radio it says.
It has a rated capacity% of 80
Rem capacity of 2451
EST CHGS 567
Then how come I can receive with no issue and when I transmit I get an issue? Looking at the battery page it looks fine to me.
N5XPM
Texas
EST CHGS 567
The radio requires much more current when transmitting, triggering the audible alert.
This has been Motorola’s battery alert since the GP300 and probably earlier.
GTR8000
NY/NJ Database Guy
BEE00
EST CHGS 567
Because as stated above, the radio draws very little amperage when receiving vs transmitting. A battery with a bad cell can look perfectly fine on the battery screen, and can probably operate just fine for receive-only.
Good thing I just found out how to turn it off under alert tones in CPS.
Which doesn't solve the underlying issue, which is that your battery has a bad cell and should be replaced if you care about having a reliable battery. I've seen this dozens of times with XTS 5000 batteries.
NVAGVUP
I used to see after market batteries have good standby voltage, but significant voltage drop on PTT. Enough where the radio would not transmit. Release PTT, and radio would RX just fine. The point is standby battery/voltage status is not an indication of battery health. Swap the battery with a known good battery. If problem follow battery, issue confirmed.
