motorola xts1500
K2NEC
NA
Not sure what you are asking and your screenshots have very tiny text so I can't even read it.
On a different note, don't use that flashcode decoder. It doesn't work well. Instead, use THIS
ncjones28677
Statesville,nc
I posted a thread earlier and sorry about the size of the picture I cant explain it .hopefully this is better.
I have no idea as to what fhashport is but I am thinking most of the functions of my radio are disabled and there is no way to activate some functions>
Can someone please explain?I am using the xts1500 as a scanner on the cps software I came across this file
86612
Well, that's showing what features are active in your radio.
Your radio will do 9600 Baud trunking
It has channel announcement and ADP encryption.
Basically an expensive analog radio.
Does not have P25.
So, depends entirely on what it is you want to do with it. If you are planning on using it as an analog receiver, then you are good to go, if it's the right bandsplit for what you want to hear.
If you want to use it for listening to a trunked system, make sure you fully and completely understand the risks and issues that go with it. You will need to understand/comprehend Non-Affiliate Scanning, or risk getting your radio remotely bricked.
If you were hoping to use it for listening to a P25 system, it's not going to do that. You can buy upgrades from a Motorola shop, if they still sell them for these radios, but it won't be cheap.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
We need the actual flashport code. That screen shows contradictory info. 9600 trunking and no digital voice does not make sense
