mototrbo cps
Newclueless
So I have to find CPS 16 in my downloads install that software and Bluetooth connection should work? Do I have to uninstall 2.0?
Newclueless
Not an OEM. It's an Amazon cable my assistant ordered. It works perfectly with 6550. On 7550 is doesn't make the connect sound but does make the disconnect sound
K2NEC
NA
I bought an Amazon cable a couple of years ago that worked but I couldn't find it if i tried. Just get an OEM.
SCFDCOMM
what's the native download filename of CPS 16 ?
I definitely have it somewhere and can likely find it easier if I know the name that comes up when it's being downloaded.
SCFDCOMM
Thanks.
I found cps_16dot0_build828 full 2.zip and cps_16dot0_build828_standalone.zip
Either of these should be okay I would think, as I'm not using the dreaded 2.0
n3obl
Ø
PA
standalone is what you want. Full includes radio management which is not needed for most people.
