MOTOTRBO Entitlement Key Installation Question
DotNM
Watchung, New Jersey
Hi there,
I have an XPR 5550 which I intend to purchase some entitlement keys for. The radio is currently programmed with CPS 16 and I'd like to keep it that way. I know Motorola no longer allows entitlement keys to be activated using CPS 16 and only CPS 2, which brings up a question I have that I'd like to ask before I try it and potentially do something irreversible.
If I were to read the radio in CPS 2 and activate the EIDs for it using CPS 2, would I still be able to program it in CPS 16 or does that trigger an upgrade to where I'd have to use CPS 2 only to program the radio going forward?
Thanks in advance for your input and experience.
DotNM
So just to confirm, I should be able to use CPS 2 to activate the EIDs and, as long as I don’t write to the radio with CPS 2, I should still be able to use CPS 16 to program the radio. Is that accurate?
FFPM571
Nashvillle
No... You have to upgrade to 2.0 your radio is probably running old firmware and CPS2.0 wont even recognize it You will have to upgrade.. end of story the CPS16 era is over the only ones still clinging on to it are the hobbyists
KJ4DHF
I was able to add EID's to my 7550E which is on CPS 16. I used CPS 2.0??? can't remember added the EID. My radio is still using CPS 16 for programming. I guess it really depends on what EID you wish to add if old firmware 2.09 will support the EID you should be fine.
K2NEC
NA
You can add an entitlement with CPS2 and still use CPS16. I guess since it doesn't "write"?
I added RX audio leveling to a 7550e running 2.09 using CPS2.
DotNM
I’m looking to add RX Audio Leveling, Text to Speech and similar EIDs. I’ve already got the radio at firmware 2.09.
Firebuff880
Boynton Beach, FL
NO, I do not believe this answer is correct.
You can no longer enable Entlements in CPS 16, and the process of Enabling Entitlements includes writing the updates to the subscriber. Once you do a write with CPS 2 you can not go back to using CPS 1 (16).
tweiss3
Is it time for Coffee?
Ohio
Incorrect. I added enhanced privacy to a 3550 with 2.0, and reprogrammed with 16.
cavmedic
Pottstown Pa
I can switch back and forth between 16.0 and CPS 2.XX all day long.
