Mototrbo rejecting simplex fequency while allowing others
tweiss3
Is it time for Coffee?
Ohio
We are going to need more information. What is the frequency? Is it analog (wide or narrow) or DMR? What radios have you had success with, and which ones have you not had any luck?
radioman2008
Batlabs user Wazzzzzzzzup (2001-Present)
System 1632 Tampa Bay Florida
He's trying to program analog 853.4 875 into the 800/900 version of xpr, I don't recall the model. It programs other 800/900 freqs, just not that one. It's not a wide/narrow issue.
Echo4Thirty
Spring,TX
There are a couple of fequencies in that radio that it wont take. I am not sure if its a CPS issue or something else. We never found a way around it.
Echo4Thirty
Spring,TX
Its not that, there were a couple of legit frequencies that we found go red when entered in a 7580. 852.3125 and 852.7625 were two of them.
Echo4Thirty
Spring,TX
Why is it just those specific ones? i could put in other 852.xx without issue and those are valid FCC channels.
FCC Channel 100 and 134 respectively
EDIT: I just checked and I have that entitlement and it still errors out on those channels. The mystery continues.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Has anyone noticed Mototrbo refusing to program a specific simplex frequency, while having no problem programming others in the same band? Any way around it?
You are finding out that Motorola is ****ed in the head, thinking they can dictate to its end users.
DMR subscribers and repeaters in the 800MHz band won't do the NPSAC(or what ever they are called) frequencies, because Motorola, decided that they won't allow it. This is to force their customers to higher tier P25 radios.
I ran into this many years ago when we wanted to replace our system with DMR. I thought Motorola had un-fubared that a long time ago because even they realized how stupid it was?
KevinC
The big K
Super Moderator
1 point
Are those "self quieting" frequencies?
N4KVE
PALM BEACH, FLORIDA
The Canadian EID bypasses that. Got it from a Canadian dealer.
