Motrola HT750
LucasJWoehrle
fort mill, sc
Hello everyone,
I am an E&I engineer at work, so anything electrical tends to fall towards me. There is an employee that has a Motorola HT750 and he is having problems with the range with his walkie, as it doesn't transmit as far as it once had. Secondly, channels 1 and 2 appear to be working as if they were the same channel. How would I go about fixing these issues? I hope I have provided enough information and am grateful for any potential help.
WA0CBW
Shawnee Kansas (Kansas City)
Not a lot you can do without some test equipment and the programing software. Examine the antenna and connector for damage. It could be a failed transmitter or bad antenna. Is this a simplex or repeater system? Here is a wild guess if it is a repeater system is one channel the repeater and one channel talk around? Can you hear on both channels ok but have reduced range on the other? You may be on talk around (for close operation) but need to be on the repeater for longer distance.
BB
cmdrwill
So Cali
Could also be a wrong or damaged antenna. The antenna connector in the radio breaks away from the circuit board usually due to the antenna being used as a radio carrying handle. A known problem.
