MPA Cloning???
FiremanSparky
Somewhere in the mountains
I have an MPA radio that is set up to recieve only, and wanted to know if it is possible to "clone" two (2) other radio's to the same set-up. The radio I want to clone is an trunked 800 MHz EDACS. Any help would be great! thanks.
F
Forts
Mentor
Ontario, Canada
The radios you wish to clone to... are they MPA's as well? If so it shouldn't be a problem. If they are a different model radio (MRK for example), I *think* you could load the personality file from the MPA and just change the radio type to MRK. I could be mistaken though... and obviously a few settings would need to be tweaked due to different abilities of each radio.
FiremanSparky
Thanks for the reply. Sorry, I should have said that the radio I wish to clone is an MPA Scan model, and the 2 radio's I wish to clone to are an MPA Scan & System model. I am somewhat new to the MPA scene, but can you do this with just the programming cables, or do you need the programming software as well? Thanks.
F
Forts
Mentor
Ontario, Canada
You would need the cable, a RIB (Radio Interface Box) and the proper programming software.
