MPT-1327
IC-R20
LoBand Nation
There has never been any Uniden scanner being able to track MTP1327.
No I remember now it was the UBC3500xlt you just had to connect it to a computer. With no discriminator tap and only a single radio needed.
dmchalmers
What part of this doesn't anyone read ? In northern Mi theres a Electric co op that went MTP-1327. Not CA! its listed as 800 mhz on the Atlanta 2 tower MPSCS? in MICHIGAN!
dickie757
Wired
Out of range
That's you that didnt read. Pacific Gas and Electric in CA was mentioned as a utility that uses that obscure mode. Your local co-op has a different name, but uses the same mode.
Check your user settings to make sure your notch filter is opened up, so you can see all of the info in your thread.
dmchalmers
Again there is a PIE&G in northern Mi using the PMSCS Atlanta 2 tower in this DB 800mhz using MTP-1327 its not Ca as other tell me.
dmchalmers
Sorry to offend but yes there is a Pie&g Co op In northern mi 1-800-423-6634 call the # your all experts but don't know the facts so call us newbes stupid ! Do your Homework!
dmchalmers
This has nothing to do with CA look up P I e & G onaway michigan 800 mhz on the Atlana 2 tower of MPSCS in this db. Has anyone used a sdr like unitrunker on a MTP-1327 system ??????
cg
Connecticut
Unitrunker is a program not a SDR
Yes, I have used an older version of Unitrunker for trunktracking MPT1327 but have not with the latest versions and have not done it in years. It was on the Western Mass Electric system (but that is in Massachusetts not Michigan and I don't know the phone number)
dave3825
Suffolk County NY
My local Electric&gas Co op just in the last few yrs switched to 800mhz MPT1327
P I E & G is also a electric& gas co op in northern Mi
IC-20 has alot of his facts wrong, PIE&G in michigan is using MTP 1327 and is a co op.
I just have to ask, where is this MTP 1327 system you keep mentioning? There are only 2 systems in the MI database using MTP 1327 and they are both 220MHz.
The Atlanta 2 tower that you keep referencing is part of a P25 Phase 2 system
PIE & G has one talk group on the system
dmchalmers
dave3825
Suffolk County NY
nothing has ever come thru TG 5471 on atlanta 2 I'm 5 miles from the tower.
Ok, and?
You stated multiple times that PIE&G, is using an MTP 1327 system on 800MHz freqs from the Atlanta 2 tower in Northern Michigan. .
Do your Homework!
My homework says that,
Atlanta 2 tower (800 MHz freqs) is part of a P25 Phase 2 system, not an MTP 1327 system.
PIE&G does hold a license for a single 800MHz frequency pair which is listed on Atlanta 2 site
PIE&G has multiple UHf licenses in the YG: Industrial/Business Pool, Trunked portion.
So again, where is this 800 MHz MTP 1327 system?
Sorry that I tell it like it is, but it looks like you need to do a little homework.
dmchalmers
Ok, and?
uhf has been dead for yrs. PIE&g has been using piggy back on Atlanta 2 since going 800mhz MTP 1327 previous repoters have said same
dave3825
Suffolk County NY
So in reality, where most of us reside, it's pretty safe to say that PIE&G is not operating an MTP 1327 system on the Atlanta 2 800 MHz site, since that site is a P25 2 system.
You asked for help monitoring MTP 1327 but have repeatedly failed to provide any details and or information needed to provide you any help at all.
Please post the MTP 1327 system details or ask the mods to close the thread.
dave3825
Suffolk County NY
did you read what i asked?
Did you read what you were asked?
You asked for help, 4 months ago, and have repeatedly failed to provide any info related to what you asked for help with, so that people could help you.
Now, your stirring it up with someone who posted a reply, to someone else, 55 days ago.
@dkscan was not even speaking to you, and quoted @IC-R20
dmchalmers
Not stiring anything up! legit question. PIE&G electric co-op in northern Mi is using MTP- 1327 an i asked if anyone usig a SDR has listened too!
dickie757
Wired
Out of range
Yet again did anyone READ what i asked? Michigan only PIE&g electric Co op
The first time Michigan or PEIC was mentioned was half-way into the first page.
P I E & G is also a electric& gas co op in northern Mi, not just Ca.
You asked if anyone used SDR to listen to MPT-1327.
You did NOT ask about UHF or 800, nor Michigan, nor PEIC.
