N2SWD
Does anyone know why MOPD transmitter is so weak.Did they turn down there power again. They barely register one signal bar in Hopatcong.
K2NNJ said:Thanks for the clarification! But how retarded is that!
If we can spend 13 million for a park that's not even finished yet (w/o lights), we should be able to fix a radio system.
OLD UNCLE SCANDAL is BACK!SCANdal said:K2NorthernNewJersey,
The technique being employed to "fix" this problem is actually quite common and is used by three systems that I am quite familiar with - two public safety and one GMRS - and for different reasons why.
Ramapo Police, in Rockland County, New York use 151.475, 151.4 as their dispatch repeater output. The input is 159.060. Ramapo uses two repeaters, an east and a west, to cover their town. The input tone (PL) is different at each tower.
Orange County (NY) EMS Control uses 153.860, 77.0 is their operations repeater output. 158.865 is used as the input. There are five seperate repeaters that cover the county, each with a unique input tone.
The Long Island GMRS Community Radio Alliance uses six repeaters, all with the same output frequency/tone and same input frequency, but unique PL tones.
In the Ramapo case, the terrain the needed to be covered is varied, from the iron-ore rich mountains around Sloatsburg, to the "urban" areas near Spring Valley. While, arguably, one site could effectively cover such a large area, 151.475 is also New Jersey DEPE's F8. I suspect they could not go "full power" on one repeater(s), in order to prevent possible interference with Jersey units operating over the border.
The Orange case is similar to Ramapo, in terms of terrain, but much more aggravated. From the banks of the Hudson River to the banks of the Delaware River, you've got a number of elevations between that prevent portable radio signals (as mainly used by volunteer EMTs) from carrying well [into a repeater that must cover the 835 square miles that make up the County].
The Long Islanders uses this arrangement to cover all of Suffolk, Nassau, and Queens counties. The arrangement allows for:
(a) licensed members to hold multiple conversations (say, some guys can use the far east repeater for one conversation, while others can use the Bronx area machine for another - and they wouldn't hear each other, or
(b) the common output allows for seamless operation as members commute from east to west (or vice-versa). Two (or more) members, each one using adjoining repeaters, can cover entire counties as they travel ahead or behind each other.
Mount Olive seems to me to have a combination of problems similair to the agencies I descibed above (anybody do a license check to see who else close by might be using their output frequency?). Yes, this method ends up tying up multiple channels on a radio to hear the same thing. But, in these days of 128 (or more) channels available on two-ways....
Another gripe could be that this method places the burden on the end user (i.e. the cop, the EMT, or the commuter) to select the correct channel in their radio to pick the appropriate repeater to transmit off of; but I look at it as placing control in the hands of the end user. I know right away if I am reaching a repeater, as opposed to using a system of voters / satellite recievers to "fix" the problem that leaves me, as an end user, only hopeing that something out there is picking up my outbound signal.
If you're a ham, as I suspect from your handle possibly being a call sign, and you're active - I am sure that you must have run into systems like this at one time or another.
Best wishes,
SCANdal
P.S.
As a scannist, thanks to this new system being implemented, you now have a distinct advantage on those days when you want to scan, but don't really want to scan. You can now program in the input frequency/PL combo used closest to your home and only listen to the units right around you. I do this all the time with a certain busy law enforcement agency near me; I just want to know when their units are operating in my neighborhood. Granted I don't hear the more distant units or the dispatcher, but like I said...I don't really feel like scanning some days. Of course, keep the regular (output) frequency programmed in the very next channel (and locked out) - so that when you do hear radio traffic that might interest you ("I've got shots fired, North...at ...") you press manual, manual again and, presto, you'll hear both ends of the conversation. A tip from old uncle SCANdal.
